B18c itr vs h22a
Old May 18, 2006 | 02:56 PM
k4rts's Avatar
k4rts
Default B18c itr vs h22a
b18c itr = http://www.jdmsource.ca/v2/product.asp?ID=17
h22a = http://www.jdmsource.ca/v2/product.asp?ID=52
which motor would you choose and why. also, if these motors were dropped into the same car, which car would run faster.
Old May 18, 2006 | 03:26 PM
H22...mainly because the ITR Engine is overhyped IMO plus expnsive as fawk
Old May 18, 2006 | 06:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
H22 hands down.
Like mentioned, the Type R motor is so incredibly overhyped and lacks balls.
Old May 18, 2006 | 10:10 PM
psx_pat's Avatar
psx_pat
Stock H22 VS stock B18C5, definately H22 is faster. Just imagine the available H22 torque on low rpms. Also with the price difference between H22 and B18C5, you can make your H22 way faster.
Old May 19, 2006 | 12:35 PM
mberndt's Avatar
mberndt
I tend to disagree...
It really depends upon what car you want to drop it into...
If it's a civic, then I would choose the ITR motor, that is if you still want to handle well. The H22 is heavier, and will throw the balance of the car off... Have you ever drove/rode in a h22 civic, it is really only good for a straight line... Also, without a LSD, an h22, with all of the extra torque, would simply melt the tires off the rims...
So unless you got a Lude or an Accord, I would have to say the ITR...
However, these are both rare and expensive, so choose wisely...
And despite what these guys say, the ITR motor is overhyped for a reason... It will run at 8000+ rpms all day long because it was designed for this operation - With low-friction coated pistons, and dual valve springs on the exhaust valves...
Old May 19, 2006 | 02:07 PM
Provocateur
On permanent hiatus
Yes, the ITR motor is way more efficient, but definitely not worth the extra cost.
With a good set of springs and shocks, an H22 Civic or Integra will perform well. The H22 is not much heavier than the ITR motor.
Old May 19, 2006 | 04:30 PM
vtec rider's Avatar
vtec rider
h22 under the hood
b18c5 is one of the best motors honda has made, so is the H22. I think the b18c5 would be faster, but way more expensive. The h22s are beasts, I got one under my hood and its the best. Go for the h22 you wont regret it when the vtec kicks in.
Old May 19, 2006 | 08:40 PM
35~ pounds is heavy? I suppose...
We autocrossed/roadcoursed our project civic in highschool with an h22 and we did fine :dunno: Tein Full Coilovers with EDFC.... 8K-9K rpm is nice...but 1.8v2.2 with about the same HP in the same car? just my opinion but I'll take the H22...
Old May 20, 2006 | 07:26 AM
mberndt's Avatar
mberndt
Hey it really is your opinion...
Hands down the ITR motor will give more bragging rights, just because of it's rarity in the H/A world...
I can't disagree about the torque though, the h22 is definitely a torque monster...
About the weight distribution, 35-40lbs can be quite a difference, besides you can't keep A/C or anything, so there goes the daily driven aspect of it... But again, H/A's are quick because of the low weight... Besides, tons of torque is no good if all you do is spin the wheels, that's what is nice about the ITR motor, it won't spin the wheels off the line like the h22...
In the end it is only personal PREFERENCE...
Old May 20, 2006 | 01:42 PM
2001TEGGSR's Avatar
2001TEGGSR
B18C * for integras - h22 for preludes...
I personally like the ability to swap OEM honda parts to achieve reliable power. Honda designed the H22 for a heavier car, and the B18c for a lighter car. Both have there advantages when put in the proper place. Budget/Available parts. If money is absolutely no option, B18c.
