what codes are these?????
Old May 2, 2006 | 07:05 PM
madman4you's Avatar
madman4you
Default what codes are these?????
ok sorry i did a search but came up short. i have a pw0 ecu and today the euc through code 3, 14, 21. i used to have this info but that went out the window,
also if anyone has a link to get the full pinout for the clips and wires into the ecu so i can check the wire harness out in this new car. thanks
again its a first gen b16a
Old May 15, 2006 | 07:08 PM
theman's Avatar
theman
Code 3 is map sensor, code 14 IACV(idle air control valve) code 21 is V-tec solenoid
