who knows torque specs for these???
Old Apr 23, 2006 | 11:22 AM
madman4you's Avatar
madman4you
Default who knows torque specs for these???
i have a booklet for my b16a however its a print off of the 360 pgs it has, i know im cheap. but i cant seem to find the torque specs for the tranny cover that goes over top this part of the tranny.
as seen in the attachment, and the oil pan??
File Type: jpg
Old Apr 23, 2006 | 01:50 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The transmission bolts are 33 ft/lbs.
Old Apr 28, 2006 | 02:40 PM
madman4you's Avatar
madman4you
any one know oil pan specs???
Old Apr 28, 2006 | 10:22 PM
Provocateur
On permanent hiatus
The Helms says 9 ft/lbs, but I usually do a 1/4-1/2 turn past finger tight in a crisscross pattern to avoid stripping the studs.
Old Apr 29, 2006 | 09:26 AM
jlicrx's Avatar
jlicrx
i believe the correct torque for the bolts for the transmission case is 21 lb ft - they are 8mm diameter bolts - some places in the manuals indicate 21 lb ft and other places 20 lb ft - L3 transmission manual says 21 - manual for B-series transmission says 20 - take your pick
Old Apr 29, 2006 | 07:45 PM
Provocateur
On permanent hiatus
What manual are you using?
I have the 1400 page Integra service manual and it says 33 ft/lbs for the tranny case bolts.
Old Apr 29, 2006 | 07:55 PM
madman4you's Avatar
madman4you
its all good guys i got it all done thanks
