B18A1 #2 cylinder dead + More
Old Mar 28, 2006 | 11:04 PM
phietnam's Avatar
phietnam
PrOJeCT aPPrEnTiCe
Default B18A1 #2 cylinder dead + More
Hello all... I have a 92 Civic Hatchback with a B18A1/non v-tec swap... I took it to a shop in town and they removed the cylinder head and resurfaced it, replaced a burnt exhaust valve, grinded my valves (pitted valve seats), cleaned the cylinder head, replaced camseals & valve cover gaskets, and did an oil change... The mechanic also told me my #2 cylinder is dead and my oil pan was leaking... What i want to know is what can i do to get the cylinder fixed? or should i just replace it, and how do i go about doing it? should i buy a new cylinder head? also where is a good place to get an oil pan? i tried www.autohausaz.com... but its not in stock... any helpful ideas and information is very appreciated... thanks
Old Apr 2, 2006 | 09:46 AM
phietnam's Avatar
phietnam
PrOJeCT aPPrEnTiCe
help? anyone? suggestions?
Old Apr 4, 2006 | 09:12 AM
kornycivic's Avatar
kornycivic
Well, usually a dead cylender means burnt rings, wich means replacing the rings, wich means you might as well do all 4 cylenders. A "cheap" solution is to tear the engine down, ball hone the cylenders, and put new rings on your existing pistons. This is an ULTRA bare bones engine rebuild. A shop will need to do this probably (or at least get someone experienced in engine building to help you) and it will not be cheap even if they just do that.
It also won't last a LOT longer...you could probably hope for 50,000 more miles (especially if you street race, drag race or otherwise beat on your car)
When rebuilding your engine, it quickly becomes cost effective (over the long run) to have cylender walls bored out (made perfectly round) put in new bearings all around, put in different pistons, low compression if you plan boost of N20, or higher compression if you want to go NA, stronger forged pistons are alwas a good bet and not to expensive, and for the cost of doing any (or all) of this you can probably just get another engine. Especially if your paying someone to do the work.
try www.hmotorsonline.com for non-vtec longblocks (your transmission is fine I assume...so you don't need a full swap, just the engine)
Good luck! Ben
