crx running lean???
Old Mar 27, 2006 | 08:37 AM
crzy000's Avatar
crzy000
Default crx running lean???
what are the problem that I can fix if my car is running lean? It run no problem but my gauge showing me that is very lean..help...
Old Mar 27, 2006 | 12:55 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What gauge are you using? If it isn't a wideband, it is worthless in telling you anything useful.
Old Mar 29, 2006 | 10:55 AM
crzy000's Avatar
crzy000
any particular brand should I get?
Old Mar 29, 2006 | 11:47 AM
Provocateur
On permanent hiatus
PLX, Zeitronix, AEM, etc...they are all decent. I have a Zeitronix, but it uses a weird lambda scale that most engine management programs throw a fit with. It does come with a great datalogging program and is relatively cheap, though.
Old Mar 29, 2006 | 12:03 PM
crzy000's Avatar
crzy000
thank's schmoo for the info.
Old Mar 31, 2006 | 03:19 PM
crzy000's Avatar
crzy000
okay got and AEM wide band air/fuel ratio gauge..showing me that my car is running lean..should I get a e-management to give a little bost on the fuel system or a vafc?
Old Mar 31, 2006 | 05:12 PM
Provocateur
On permanent hiatus
What does lean look like?
You mentioned it is running fine. If it is running fine and supposedly lean, it must be fine. If you richen it up, your gas mileage will drop.
Old Apr 14, 2006 | 01:17 PM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
What are you calling lean? 15:1 is your car NA or FI? Whats the plugs look like? Is there detonation?
