del sol with GSR need some help
Old Mar 23, 2006 | 10:28 AM
psychoblue23's Avatar
psychoblue23
Default del sol with GSR need some help
So my friends 93 Del sol is in the hop and it has a 94 GSR motor. Upgrades are skunk2 intake mani and Greddy header. After they installed the intake mani the car will no longer go into Vtec.. just looses power. Checked to see if it was throwing any codes but its not. Knock sensor has been replaced already. Clueless as to what else to check. If anyone has any ideas let me know thanks a lot...
edit: forgot to mention car was running fine until recently. It has the GSR ecu also and problems didnt arise til intake mani was put in. Everything seems to be in order.
James
Old Mar 23, 2006 | 01:09 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
this is why i like to do all my own work to my car.
is you vtec solenoid plugged up???
Did you let the shop know of the problem??
Old Mar 23, 2006 | 01:24 PM
psychoblue23
Vtec sol IS plugged in.. and "the shop" is just his cousin at goodyear. We use the place for the lift and for alignments ^_^
Obviously something has to have been not been put back together correctly or not at all.. I didnt do the work.. Im jsut tryin to help think of more things to check to help him out.
Old Mar 23, 2006 | 01:39 PM
psychoblue23
ok so I just found out its not a SKUNK2 IM its a type R copy made by Pro Series? Also he was using a write up from HT on how to install it. Problem is the write up is for a BLOX IM and im not sure if it would apply to diff types. Im checking all the vacum hoses now to make sure they are all in the correct places. Would a misplaced hose cause the car to die at vtec?
Old Mar 23, 2006 | 02:16 PM
i thought the Skunk2 mani didnt fit the GSR? or was it the b16... one of them h: i may be mixing it without another engine
and how do u know its not hitting vtec?
Old Mar 23, 2006 | 02:20 PM
crzy000's Avatar
crzy000
with all the mod..did you reset the ecu after?
Old Mar 23, 2006 | 08:25 PM
psychoblue23
as soon as it gets to like 3500 rpm the car just looses all power.. so technically its not running correctly period.
As for the IM not fitting.. I was mis-informed its not a skunk2 its some pro-series type r copy? I ahve no idea... I was jsut tryin to help him troubleshoot the thing.. he has no idea whats causing it to run that way.
Old Mar 23, 2006 | 09:20 PM
psychoblue23
hmm i was just checking online.. that pro series IM IS a skunk2 haha and it DOES fit the GSR at least it says it does...
