Ignition Timing
Old Sep 18, 2002 | 08:55 PM
Gasoline Fumes's Avatar
Gasoline Fumes
Automotive Enthusiast
Default Ignition Timing
My mother's car, a 1991 Civic Wagon, is pinging. I took out the Bosch Platinum plugs and put in NGKs, no difference. I fed it about a gallon of water through a vacuum line and made lots of steam, still no difference. I checked the timing and it was retarded according to the light, but the distributor is fully advanced. So I checked the cam timing (it was correct) and changed the belt, which was loose. No change yet. I have backed off the distributor to stop the pinging, but I would like to have the timing where is should be. Two things possibly related: a crank angle sensor and 02 sensor code (have not come back since I reset the ECU). And at WOT it doesn't usually go past 6000 rpm (redline 6500), it just slows down and stays at 6k (smoothly, no bucking, sputtering, etc.) unless I back off the throttle a little.
Any ideas? Can timing lights be wrong? Am I missing something?
Old Sep 19, 2002 | 04:32 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Are the injectors clean?
Also, what shape are the plug wires in? If they have any hardspots in the insulation the resistance of the wires could be screwed up.
-Harry
AIM: NDcissive
Old Sep 19, 2002 | 11:41 AM
Gasoline Fumes
The wires seem ok, I guess checking the resistance wouldn't hurt. I'm not sure about the injectors. What's the easiest/cheapest way to clean them? Still wouldn't explain the fact that I can't get the timing right, it won't go far enough to hit the red mark on the pulley.
Old Sep 19, 2002 | 12:44 PM
1stGenCRXer
My thinking is that if it's running too lean it will detonate, and that limits your timing.
Just pull out the injectors and soak them in carb cleaner.
Old Sep 19, 2002 | 05:42 PM
Gasoline Fumes
OK, I'll try that.
Old Sep 20, 2002 | 08:37 PM
Gasoline Fumes
I probably should of taken the o-rings off of the injectors. They swelled up in the carb cleaner and I ripped one of them trying to get an injector back in.
Old Sep 21, 2002 | 10:53 AM
1stGenCRXer
lol, oh yeah 1stGen's after-the-fact warning: Spraying rubber items with carb cleaner is OK, soaking them causes them to swell to 10000 times their original size and 1/100th of their density/strength.
Old Sep 21, 2002 | 05:45 PM
Gasoline Fumes
I got some o-rings at a hardware store that seem to seal it for now until I get the right ones. The timing didn't change. I might just give up, since it runs good where I have the distributor now (probably about 5 degrees retarted from the red mark).
Old Sep 22, 2002 | 12:17 AM
1stGenCRXer
Have you been checking the timing with and without vaccuum advance? Kinda sounds like the lines are reversed.
Old Sep 22, 2002 | 09:42 PM
Gasoline Fumes
There is no vacuum advance, it's all electronic. And I have been putting a jumper across the "ignition timing adjusting connector."
