Skunk2 IM coolant pipe 3/8 Help on plugging it
Old Mar 2, 2006 | 09:01 PM
Robstunner's Avatar
Robstunner
y0! Vito!
Default Skunk2 IM coolant pipe 3/8 Help on plugging it
Well, i got done with my sk2 IM install, and have a Q for you guys/ there is a 3/8" coolant inlet/outlet connected to the larger one that goes into the head. now, the larger one is used, but the little one needs to be plugged off. i got a large bolt and 3/8' hose and put the bolt through it to see if it would work. Its working, but its SLIGHTLY leaking. is there anything else i can use/buy thats made specifically to plug a 3/8' pipe?
Thanks
Rob
Old Mar 2, 2006 | 09:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I just bought a set of vacuum caps to plug the smaller coolant port. I wouldn't recommend doing what you are doing, just buy some vacuum caps at your local autoparts store.
Old Mar 3, 2006 | 07:18 AM
Robstunner's Avatar
Robstunner
y0! Vito!
coo. im just afriad of it blowing out. theres not that much pressure going thoguh those lines is there? i would assume if any there would be positive pressure?
Old Mar 3, 2006 | 09:55 AM
Provocateur
On permanent hiatus
There is a little bit of pressure but the vacuum plugs come in several different sizes, so just stick one on there that fits very snugly and it shouldn't give you a problem. I have had mine plugged for a few months with no problems.
Old Mar 3, 2006 | 10:45 AM
Robstunner's Avatar
Robstunner
y0! Vito!
nice, yeah i got a 3/8's vacuum plug. ima put it on but im afraid of doing it b/c i know theres gonna be coolant spilling
Old Mar 3, 2006 | 02:08 PM
Provocateur
On permanent hiatus
Just use a small zip tie to keep it on if you are that worried about it. It should be fine.
Old Mar 3, 2006 | 04:41 PM
Robstunner's Avatar
Robstunner
y0! Vito!
well no, i mean once i take the plug out, its gonna leak untill i plug it up again. i have a 3/8 cap with a clamp on it ready to go.
Old Mar 4, 2006 | 11:49 AM
Robstunner's Avatar
Robstunner
y0! Vito!
will this pulley work?
Old Mar 4, 2006 | 12:44 PM
Provocateur
On permanent hiatus
Yes
Old Mar 4, 2006 | 07:43 PM
Robstunner's Avatar
Robstunner
y0! Vito!
yeah sweet. i was reluctant b/c of it having 2 spots for the cable. its actually a throttle pulley from a automatic car, which is why it has taht extra cable spot.
thanks alot schmoo, uve been alot of help
thank
rob
