Got my code, but what does it mean?
Old Feb 15, 2006 | 07:27 PM
shelby's Avatar
shelby
Default Got my code, but what does it mean?
So what exactly does "EGR Valve Lift Insufficient Detected" mean? The car is a 97 Acura 3.0 CL, diagnostic code P1491. Am I looking at something serious or hopefully something I can fix myself? Maybe someone here can point me in the right direction..
Old Feb 15, 2006 | 08:39 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Your EGR valve probably just needs to be cleaned out. I would pick up some sort of shop manual to help you locate the valve, so you can clean it out.
Old Feb 16, 2006 | 06:17 PM
RootsGSR's Avatar
RootsGSR
You need to replace the EGR valve. The solenoid itself is bad. They're notorious on the honda v6. Make sure you get an OEM. Also, wouldn't be a bad idea to clean out the EGR port. Remove the intake manifold and you'll see a black carbon filled circle on the underside. Use carb clean to break down the carbon and start with a small drill bit by hand and clean out that port. Make sure to clean it thoroughly and not cut into the aluminum.
Old Feb 22, 2006 | 06:51 AM
eaf's Avatar
eaf
Changed my mind
