what is the best intake mainfold.
Old Jan 30, 2006 | 03:37 PM
KarrNtegGSR's Avatar
KarrNtegGSR
Default what is the best intake mainfold.
Who makes the best inake mainfold and does any one have poduct testing with dyno proven results? On any thing for a 1998 intergra GSR.:dunno:
Old Jan 31, 2006 | 05:08 AM
shivers's Avatar
shivers
Moderator Alumni
The "best" is a relative term. Depending on the engine build, different IMs will work better than others. If you're just looking as swapping out the stock unit to get additional power, don't waste your money. The stock Honda manifolds flow quite well until you're making some serious n/a power or flowing a ton of air on a boosted engine.
2005 s2000
Old Jan 31, 2006 | 12:36 PM
HcOiNvDiAc's Avatar
HcOiNvDiAc
GOT HONDA?
i've heard good things about skunk 2
Old Feb 3, 2006 | 06:28 AM
KarrNtegGSR
Default I mean best in increasing torque and hp, also 1/4m times
I mean best in increasing torque and hp, also 1/4m times. Also have capadability install a small shot nos directly some time when I have the dinero.:dunno:
Old Mar 4, 2006 | 06:20 PM
adamk480's Avatar
adamk480
Default Skunk2
If u have a GSR, and its not JDM (B18C) then the Type R is out.. i believe. BUT the Skunk 2 will get you similar R results/specs and will bolt up.
Old Mar 8, 2006 | 07:08 AM
AcuraFanatic's Avatar
AcuraFanatic
Unless you're pushing a lot of airflow, a big bore intake manifold will make you lose air flow velocity and it will kill your low end torque.
