Same Engine - Different (Very Different) Oil?
Old Jan 22, 2006 | 11:40 PM
Accord2005NJ's Avatar
Accord2005NJ
Default Same Engine - Different (Very Different) Oil?
Hi,
I just went to www.castrol.uk.co (Catrol's web site in UK) and clicked on (bottom left corner) link "what oil should I use". I found out that for 2003+ 4cyl Accord Engine (I-vtec etc.) they recommend 0W-40 oil while here (US) 5W-20 is recommended.
Now, I know I have been going on about this but this really makes me believe that the only reason we (in the USA) are being told to use 5W-20 is for fuel economy purposes while Euro market gets (a better) recommendation to use oil that is better for the engine's longetivity?
Can anyone explain this to me? Am I missing something?
Thx
Old Jan 23, 2006 | 06:03 PM
b16ahybrid's Avatar
b16ahybrid
the oil weight rating determins the thickness of the oil.
10/30 for example has a viscosity rating of 10 when cold and 30 when warmed up....(both at a standard temp)....
Usually climate determins which oil you should use....
Old Jan 23, 2006 | 06:38 PM
sherwood's Avatar
sherwood
I missed Sean
different climates.
Old Jan 23, 2006 | 07:01 PM
Accord2005NJ
Thx
I will be using 0W-40 in my cars from now on.
Old Jan 23, 2006 | 07:10 PM
sherwood's Avatar
sherwood
I missed Sean
do you live in europe? in europe they drive much faster, higher engine loads. there are different climates. hondas know their engines, put in what they tell you.
Old Jan 23, 2006 | 08:48 PM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by Accord2005NJ
Thx
Why would you do that?
Old Jan 24, 2006 | 07:06 PM
Accord2005NJ
Hi,
Finally I decided to go with Mobil1 5W-30 Synthetic. I just think 5W-20 is too thin and introduced only for CAFE (CorporAte Fuel Economy) reasons.
Old Jan 24, 2006 | 07:25 PM
sherwood's Avatar
sherwood
I missed Sean
i personally would go with 5w30 or 10w30 depending on my climate at the time. tho right now it's winter and i'm running 10w no problem...
Old Jan 25, 2006 | 09:56 AM
Tigerpower's Avatar
Tigerpower
Would it be the same regardless of year? I'm using 10/40 on my '94 accord, should I switch back to 5/20?
Old Jan 25, 2006 | 10:03 AM
sherwood's Avatar
sherwood
I missed Sean
where in the us do you live... i'd stick with x-w30 x either being 5 or 10 depending on your climate, 5 for colder climates (temps go below 20 during cold season) or 10 for warmer climates
