exhaust manifold broke HELP HELP
Old Jan 15, 2006 | 09:27 AM
96civichxob1's Avatar
96civichxob1
New to the bump
Default exhaust manifold broke HELP HELP
I need help and advice on anything i might encounter when switching out a exhaust manifold on a 1996 honda civic hx, the old failed inspection b/c it has a leak, so i bought a new one and i am going to switch them out, i have a haynes manual. So i am just curious if i need any "special" tools other than the obvious, or anything else i should know....oh and on a difficulty level, 1=easiest, 5=take it to a garage, let me know if you can rate it!!!!!!!!!! thanks for all your help guys.
Old Jan 15, 2006 | 10:21 AM
b16ahybrid's Avatar
b16ahybrid
If you can change your own oil you can swap manifolds....I believe 9 nuts on the head and a few down where it connects to the cat......viola.
Old Jan 15, 2006 | 01:10 PM
96civichxob1
New to the bump
thanks for your help, i've heard that like you said, if you can change your oil, thats that....so we'll see, and thanks again.
