Please help with h22 swap!
Old Jan 11, 2006 | 07:58 PM
JasonST's Avatar
JasonST
Default Please help with h22 swap!
Hey gotta another question, just about to bolt the engine into my integra and with the HCP mounts i'm useing it says to "Remove the studs from the H/F series transmission and replace them with 14mm bolts." And i'm thinking to myself, maybe it's just cause i'm new to this, but why can't I use the studs, why do I have to go to the trouble of replacing them with bolts? And if I have to remove them, how do you remove them cause they seem welded onto the tranny. Thanks for any help in advance!
Old Jan 31, 2006 | 01:52 PM
waaBAAH's Avatar
waaBAAH
they do screw out. get a pipe wrench or vice and start turning....lefty lucy right tighty. i belive just one stud/bolt needs to come out. not all three. line up your mount to the tranny......it shouldnt line up but you will see (if you picture no studs/bolts) that it will line up. hope that helped
