Help, integra motor problem
Old Jan 10, 2006 | 08:04 PM
EgRocker's Avatar
EgRocker
brain fart
Default Help, integra motor problem
i have a problem and non of my friend reallie understand what to do . i was woundering if you guys knoe what's the problems would be. i get about 140 miles off a full tank . my spark plugs turn black after 5 min on idel. it seems to be running rich for some reason . it's a b18b motor in a eg.
Old Jan 11, 2006 | 05:54 AM
mr.crx's Avatar
mr.crx
check your 02 sensor
Old Jan 11, 2006 | 06:16 AM
EgRocker's Avatar
EgRocker
brain fart
would the check engine light turn on if it was the o2 sensor ? i don't have anycheck engine light .
Old Jan 11, 2006 | 06:21 AM
b16ahybrid's Avatar
b16ahybrid
Not always, what mods are done to your engine?
Old Jan 11, 2006 | 06:53 AM
mr.crx's Avatar
mr.crx
ya not always but it can make your check engine light go on. since your check engine light is on that means its throwing a code. on the ecu there is a little hole that will have a little red light flashing out how many times it blinks and tell us if they are fast blinks or slow blinks. then go and find what the code is. there are many places capable of telling you. if you call a honda honda place they will be able to tell you what that code represents.
Old Jan 16, 2006 | 09:44 PM
EgRocker's Avatar
EgRocker
brain fart
i just popped in a new o2 sensor. not thing has changed. what else could it be ?
Old Jan 16, 2006 | 10:43 PM
AcuraFanatic's Avatar
AcuraFanatic
OEM cap rotor/plug wires? What temperature plugs?
Old Jan 17, 2006 | 02:40 PM
EgRocker's Avatar
EgRocker
brain fart
these are just nomal spec ngk plugs . i'm been replacing them like crazy eversence this problem started . do u think it could be the map sensor ?
Old Jan 17, 2006 | 03:38 PM
FlatHatchBlack's Avatar
FlatHatchBlack
It could be the map or tps sensor, but check the pressure at the regulator, also, if your fuel return line is clogged it will make your car run rich, but i'm guessing its a faulty regulator.
Old Jan 18, 2006 | 10:02 AM
riskyb's Avatar
riskyb
check to make sure the little o-ring is still on the map sensor
