Header question.
Old Jan 5, 2006 | 07:45 AM
psx_pat's Avatar
psx_pat
Default Header question.
Ok,I have PR-3 ECU OBD-0 with B16A head and B20B block. I want to change my header with Integra type-R (4-1). The problem is PR-3 ECU using 2 O2 sensors on cylinder 1-4 and 2-3. So, where I should install the O2 sensors on 4-1 header and still using my PR-3 ECU? Also what you guys think type-R header for my engine set up (the engine is pretty much stock)? Thanks.
Old Jan 5, 2006 | 08:59 AM
Illegal B16's Avatar
Illegal B16
New Zealand
put it at the top. i would get the lighter magan racing type-r header in stainless. Much cheaper as well. Comes with a bolt to block off the lower hole.
Old Jan 5, 2006 | 01:43 PM
psx_pat's Avatar
psx_pat
I'm not not sure about what you mean put it at the top? In what cylinders? 1 O2 sensor on cylinder 1 and the other o2 sensor on cylinder 2?
Old Jan 5, 2006 | 02:17 PM
Illegal B16
New Zealand
nevermind.
