turbo questions
Old Jan 3, 2006 | 05:36 PM
92b18hatch's Avatar
92b18hatch
Default turbo questions
i want to know what i will need to turbo a stock gsr motor. what kind of boost can a stock engine take? do i need a fuel management if i only want to run like 5-7 psi? help me out
Old Jan 3, 2006 | 05:55 PM
b16ahybrid's Avatar
b16ahybrid
Your motor (along with the b18c5, b18b1,etc) can handle about 300whp for daily driving...+ or - a little depending on your tune...
PSI means POUNDS PER SQUARE INCH not horsepower....Now research, i'm sure you did it in high school once or twice...
Old Jan 3, 2006 | 06:42 PM
92b18hatch's Avatar
92b18hatch
all want somone to tell me everything that i need to make it work you fag, thanks for the help
Old Jan 3, 2006 | 07:36 PM
b16ahybrid's Avatar
b16ahybrid
edit...
Old Jan 3, 2006 | 08:22 PM
92b18hatch's Avatar
92b18hatch
sorry brooo, ive got a kid and work 60 hours a week, so i dont have 10 hours a day to sit on here. all i asked for was some help, so stop being a pussy and just answer my questions.
Old Jan 3, 2006 | 10:43 PM
b16ahybrid's Avatar
b16ahybrid
You need a manifold, a turbo ( I recomend at least a t3t4),a down pipe, tuning (including fuel injectors,fuel pump, and tuning evice such as hondata)..Uberdata is cheaper but requires more rersearch...)
2.5:" exhaust will suffice for a stock motor....
Tune with a quality tuning device such has hondata,aem, or uberdata and you'll be good for 300whp..
Also you need a intercooler, blow off valve, charge pipes.....
Old Jan 3, 2006 | 11:11 PM
92b18hatch's Avatar
92b18hatch
do i need a differnt map sensor?
Old Jan 4, 2006 | 09:01 AM
b16ahybrid's Avatar
b16ahybrid
Depends on how you tune the car, honda maps will read up to about 11psi of boost.
