clutch, pressure plate; cable, hyrdro
Old Dec 13, 2005 | 09:49 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default clutch, pressure plate; cable, hyrdro
i want to use an itr pressure plate in a y1 cable transmission. i know the clutch disc is the same for hydro and cable trannsmissions, but what about the pressure plate? thanks
Old Dec 14, 2005 | 01:24 AM
bambbrose's Avatar
bambbrose
I think they are the same as well. The pilot bearings are also the same, but the throwout bearings are different
Old Dec 14, 2005 | 05:52 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
so if i am bolting the entire itr clutch/flywheel/bearing assembly to a cable tranny, what do i need to get that wont work from the itr?
Old Dec 14, 2005 | 10:34 AM
bambbrose's Avatar
bambbrose
you just need a cable throwout bearing.
Plus you don't bolt the clutch to the trans, you bolt it to the engine lol.
One good thing about the itr clutch and flywheel is that it's pressure plate uses 9 bolts instead of 6 like most of the other oem flywheel/clutches.
This makes it a bit stronger and less prone to slipping.
Bearing wise there is only the two bearings, the pilot and the throw out. I think you need to change both of them as it is simple to do while you are in there and they are high wear bearings in hondas. Try and get OEM replacements or at least Japanesse made bearings
Old Dec 14, 2005 | 03:31 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
yea, i know where u bolt it to. just said it wrong.
