Engine Swap Help
Old Dec 13, 2005 | 05:33 PM
Funk Grenade's Avatar
Funk Grenade
Default Engine Swap Help
Alright..
I'm purchasing a k20a2 motor/transmission that is going to be swapped into my 02 civic ex.
Hasport has the axles and the mounts.. but--I can't find the internal wiring?
Does anyone know where I can find this?
Or.. If I'm retarded and I don't even need it?
Thanks in advance.
Old Dec 15, 2005 | 12:38 AM
bambbrose's Avatar
bambbrose
You'll need the charging and engine wiring harness that comes with the engine.
Check out k20a.org and k-series.com
both are good resources for K series swaps.
You will need hondata kpro I believe, unless you swap the immobilizer and ignition assembly with the motor.
Old Dec 25, 2005 | 08:28 PM
knightsil-gold's Avatar
knightsil-gold
lucky dog!!!
