Idle drop..on jrsc gsr
i was wondering why my idle drops so low it feels like the car is going to turn off....my car at idle its around 500-700rpm...then i drive it and put the clutch in and drops hella low..i was wondering if its like that because of my supercharger....is the idle suppose to be set that low for the supercharger?
thanx!!!!
thanx!!!!
You may want to check to see if the air/mix screw in the TB didnt move in or out. If it did, just turn it all the way in and back it out 1 and a half turns. That should be close to factory, then slightly adjust either way until its perfect.
