Wiring Help Itr Hatch
Old Dec 10, 2005 | 08:28 PM
GotJew's Avatar
GotJew
Eg B18c5 Equipped
Default Wiring Help Itr Hatch
Sup,
I had a question and needed some help. I have a 93 cx hatch with a 98 ITR motor and, it has a rewired factory Cx harness which works fine no problems. I haven't been running an 02 sensor in almost 2 years and i want to get it working because my motor is running lean. I did a search and followed and i found that everyone had the same answers for the converting my 1 wire to a 4 wire setup. I know it was like A6,D14 and, D22 or something like that but i needed some more help because it ended up not working. I have an OBD-1 P30 so if anyone can help i would greatly appreciate it also, btw i was using an OBD-2 B16 O2 and the wires are 1 white, 1 green and, 2 black i needed to know which one is which i am assuming the white is Signal and, green is sensor ground? The black are proly heater circuit? Thanx for reading appreciate any help later.
Old Dec 11, 2005 | 02:28 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Screw all that, and get it tuned, it wont run lean then :P
