Engine starting troubles
Old Dec 8, 2005 | 05:43 AM
hatcher's Avatar
hatcher
Default Engine starting troubles
Simple question - probably harder to answer.
99% of the time my '94 Prelude 2.3Si starts up fine. Occasionally (the other 1%) it will start then instantly cough and die, after that it's a bugger to start. If you leave it alone for five to ten minutes and then try again that will usually work but sometimes you have to be really persistant, and feather the throttle until it catches and continues to run. Once started it's absolutely fine again.
Any ideas?
Hatch
