no compression no start timing ?
Old Dec 12, 2005 | 10:30 AM
toy720's Avatar
toy720
ok i yanked the head off after new compression tester and still no compression at first look everything looked ok but when shining a light on each combustion chamber the exhaust valve are slightly open on every chamber if you take a hammer and tap them back it will seat but im assuming they are slightly bent since the belt slipped if anyone thinks it might be something else i would appreciate the feedback.
thanks brad
Old Dec 12, 2005 | 01:14 PM
JimBlake's Avatar
JimBlake
Originally Posted by toy720
... but when shining a light on each combustion chamber the exhaust valve are slightly open on every chamber...
I think you just found your problem.
Your valve guides might be damaged too, so you might have to do more than simply replace the valves.
Old Dec 12, 2005 | 02:31 PM
toy720's Avatar
toy720
yea im going to send to a machine shop ive used before
thanks for all the help
brad
