CTR or ITR pistons in ls block?
Old Sep 11, 2002 | 03:44 PM
Snoopy's Avatar
Snoopy
been there done that
Default CTR or ITR pistons in ls block?
which will have higher compression in an ls block with b16 head?
Old Sep 11, 2002 | 04:07 PM
dubcac's Avatar
dubcac
I
CTR
Old Sep 11, 2002 | 06:27 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
http://www.c-speedracing.com/howto/c.../compcalc.html
Enjoy! :thumbup:
Old Sep 11, 2002 | 07:14 PM
Snoopy's Avatar
Snoopy
man that came out alot higher than i thought. :thumbup:
Old Sep 11, 2002 | 07:35 PM
DB7 2.0's Avatar
DB7 2.0
Banned
CTR pistons will definitely yeild a higher compression ratio..but you'll also probably be slapping the top of the pistons with the valves like a pimp slappin his hoes.
Old Sep 11, 2002 | 08:46 PM
MikeSarr_GSR's Avatar
MikeSarr_GSR
yea man the LS crank is different, 89mm stroke yeilds more CR when fitted with a taller piston dome. the only way to tell if is you clay the motor when you build it if you have enough piston to valve clearance. the valve reliefs on the CTRs are DEEP, they are made for it, also consider the stroke on the B16 is 77.4mm the deckheight on the B18A/B is I believe is the same as the GSR/ITR.
The JDM ITR pistons with the LS crank will give you a good 11.3-11.5:1 at 81.25mm while the CTRs running a higher 12-12.2:1. It all comes down to what you research and do yourself. Thats pretty tall compression my friend, however it may be managable..?! I would invest some time researching the risks running 12:1 on the street.
Old Sep 11, 2002 | 08:49 PM
Snoopy's Avatar
Snoopy
oh yeah im still doing ALOT of research. :thumbup:
happy
Feb 17, 2006 08:27 PM
Dthreat619
Dec 4, 2005 03:10 PM
churchboyracer
Engine Swaps, Tech & Tuning
6
Dec 31, 2004 02:37 PM
ManoloCRX
Nov 1, 2004 02:59 AM
RedUSDM'97TypeR
3
Dec 31, 2002 07:14 AM
