ek swap..no start..lots of problem.
Old Nov 17, 2005 | 07:33 AM
97Civic123's Avatar
97Civic123
Default ek swap..no start..lots of problem.
my friend did a swap halfway and bailed on me..left me stuck cuz he's "busy". 96 hatch with a 99 b16a2 swap. did power floor & dash harness also for power doors and 99 center console change. checked the ground in the engine. one going to the near the valve cover. one to the thermostat, and one to the tranny. (am i missing one) Car will crank, but won't start. no spark. (replaced the dizzy, but no go) Also when i turn the key. the guage cluster lights won't turn on. but the hazard light works and the windows didn't roll up(did i not ground a wire under the dash?)...these plugs are plugged in either. i dont know where they go. any help appreciated...i need to get this thing running. it's been sitting there for over a year now. If anyone is around the philly, pa area, and would like to give it shot, please pm me. I will pay you for you time.
Old Nov 17, 2005 | 08:09 AM
teg92's Avatar
teg92
WHAT OK YEAH!
some friend you have, are the spark plug wires in the correct order? What ECU and wiring harness are you using?
Old Nov 17, 2005 | 05:06 PM
97Civic123's Avatar
97Civic123
yes the spark plugs are correct. wiring harness is all stock 99 civic si floor, dash, and engine, and ecu
Old Nov 17, 2005 | 05:49 PM
teg92's Avatar
teg92
WHAT OK YEAH!
did you connect all the grounds? Check fuses
Old Nov 17, 2005 | 05:57 PM
97Civic123's Avatar
97Civic123
how many ground are there under the dash?
Old Dec 16, 2005 | 05:23 PM
93jdmgsrhatch's Avatar
93jdmgsrhatch
try running power and ground directly to the fuel pump and start it
