B20 bottom end Q's?
Old Nov 8, 2005 | 04:17 AM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
Default B20 bottom end Q's?
Thinking of doing a B20 bottom end on a B16 head.
*Does the B20 bottom end use the same engine mounts as the B16? will it bolt into my '94 EG HB?
*What work/parts has to be done/needed to bolt the two together (better head gasket etc etc?
*Is it worth while or should i just get pistons of a ek9 type R and raise the compression instead??
thanks for any help!!
Old Nov 8, 2005 | 08:24 AM
psx_pat's Avatar
psx_pat
Well,I don't know about the engine mounting. But definately you feel much more power on low end cause bigger displacement. Check this site:
http://www.importreview.com/d_2.0.html
Old Nov 8, 2005 | 08:59 AM
b16ahybrid's Avatar
b16ahybrid
Just like an ls/vtec but with a b20 bottom end.
Yes it's the same motor mounts.
No I cant answer your question as to if it's worth while as I have no idea what you have in store for your car, thats something your going to have to answer on your own.
Old Nov 8, 2005 | 02:12 PM
dubcac's Avatar
dubcac
I
You'll need to at least replace the rod bolts in the B20 block to hold up to daily 8k rpms. You'll also need a Golden Eagle VTEC Conversion kit for the headgasket, dowel pins, oil lines and fittings necessary for the VTEC head going onto a nonVTEC block.
Old Nov 9, 2005 | 04:09 AM
B16a2VTIguy
Built B16a
kool thanks for all the help.....I wana go all motor so im just tryin to decide myself whether i want it or if EK9 pistons, I/M,stage 2 cams,ECU etc will be enough for what i want, i want about 205bhp-220bhp (at the fly wheel not the whp) so im i dreaming or is this a poss? I have a B16a2 BTW.
thanks agen. ste
