Turns Over But Dont Start
Old Oct 24, 2005 | 10:43 AM
onegreedy's Avatar
onegreedy
Default Turns Over But Dont Start
hi i just bought a 1994 del sol car was great for 3 days then one day it just wouldnt start, it has a brand new main relay could it be a diferent relay or something else ,
could something cause a main relay to go out, maybe a short or something ??
thanks
Old Oct 24, 2005 | 10:44 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
How does the distributor cap and rotor look? Spark plug wires? Spark plugs?
Is it even getting spark?
Old Oct 24, 2005 | 10:50 AM
onegreedy's Avatar
onegreedy
this is the thing, i took it toa shop to have it looked at and they are just holding the car, they said it is probly some wiring issue and want me to write a check for like 500 bucks to fix it, it is an off and on problem, first they said there was no problem then it wouldnt start again, i will just tow the car home tonight, and check for spark and fuel, my main concern is if the main relay went out and was replaced and now it needs another one could something be frying the main relay??
Old Oct 24, 2005 | 11:06 AM
jlicrx's Avatar
jlicrx
probably bad igniter in distributor
Old Oct 24, 2005 | 11:26 AM
Provocateur
On permanent hiatus
Yeah, that would be my guess. It sounds like the ICM is on its way out.
If you can hear the fuel pump whine when you turn the key, your main relay is fine.
Old Oct 24, 2005 | 12:12 PM
onegreedy's Avatar
onegreedy
ok i can feel the main relay click when i turn the key on, but i still have not had the chance to check if its a fuel problem or spark problem
one think i know is i tried to start it using starting fluid and still nothing so i am definatly going towards spark!! i know the disties are notorious for going out on thhe d15 so i am wondering if i should swap out the distie
i cannot hear the fuel pump though, but i dont know if thats normal in the del sol
Old Oct 24, 2005 | 08:16 PM
jeterkm02's Avatar
jeterkm02
hatchbacks r my anti-drug
definately check to see if its sparking. u have 2 choices on doing so...
A: pull out your plugs and reinserting them into your spark plug wires, then attempt to start the car and have a friend watch for a spark.
or
b: hook up a timing light and see if it flashes when u crank the motor.
Old Oct 25, 2005 | 07:59 AM
onegreedy's Avatar
onegreedy
Default car is running but now has 2nd problem
or
OK...... CHECK THIS OUT
i went to the shop , they charged me 30 bucks to look at it and i dont even think they did that well i was under the dash with t he key on and just for freakin thrills i was like moving around wires, all of a sudden the fuel pump kicked on, i am guessing when they removed the old alarm and rewired the system they have a few loose wires there, i will spend like 4 hours soldering every dam wire there
but i still have a problem car runs a little rought on low rpm, i am thinking this is becuse it is a d15 engine with the d16 vtec ecu any info would be helpful
