b18a1 build questions
Old Oct 14, 2005 | 10:36 AM
gjown's Avatar
gjown
Default b18a1 build questions
Ive decided not to do the ls/vtec because of reliability problems.So now Im gonna do a all motor b18a1 build. my question is, can I build this motor to do a 13-14 quarter mile time? Can I make it fast but still be a daily driving reliable car? Can I put jdm internals in it? The car it going in is either a delsol or civic eg.
Old Oct 14, 2005 | 10:47 AM
b16ahybrid's Avatar
b16ahybrid
What reliability issues are you worried about? A properly built lsvtec will be just as reliable as a stock gsr or ls. Cut corners you will sacrifice reliability.
I would build a high compression lsvtec set-up if you going for a N/A set-up. Add some headwork and cams and you should have no problem running 13's in a hatch.
Old Oct 14, 2005 | 11:21 AM
EkcivicBeast's Avatar
EkcivicBeast
how much do u thinkthat time will increase in a DA body??
Old Oct 14, 2005 | 04:37 PM
b16ahybrid's Avatar
b16ahybrid
With the same driver....maybe upwards of .5 seconds depending on your curb weight. I don't think a DA teg weighs much more then a eg hatch....probably still in the 13's....
It all depends on the parts, tuning and the driver, who knows maybe with the right set-up, you could be in the high 12's (w/slicks and some weight reduction)....
But I wouln't think a whole lot more.....maybe only 2/10th's??
