honing my block
Old Oct 6, 2005 | 07:12 PM
EkcivicBeast's Avatar
EkcivicBeast
Default honing my block
wat is the difference between get your block honed and sleeved? cuz i have bseries block that i am rebuilding, and i am hearing that you must hone the block b4 pistons r installed, is dat tru? and if so can and der is a diff, between honing n sleeving can i just get da block honed n leave it at dat?
Old Oct 6, 2005 | 08:11 PM
b16ahybrid's Avatar
b16ahybrid
Sleeving is when you have the cylinder sleeves replaced with either new stock ones or aftermarket ones. I't's only required when you damage your sleeves beyond repair (by boring and honing).
Honing removes a lot less material and leaves a cross hatch design in the cylinders to help the reings seat.
I recently had my block sleeved (aftermarket) by golden eagle. When I got it back I took it down (along with my pistons) to my local machine shop and had them bore the sleeves (enlarge them close to the diameter you need) to about .002 pistons to wall clearance, then they honed it the rest of the way (to about .003 final piston to wall clearance)...
A bore and hone runs about $130 while a sleeving job runs about $749 for all 4 sleeves.
Old Oct 7, 2005 | 05:50 PM
EkcivicBeast
thanks that helped alot, so if i just leave the stock sleeves in there do i have to worry about reboring n sleeving for that ring to wall clearance if i am replacing the pistons wit CTR pistons(standard 81mm),or should the rings seal properly with just an honing job??
Old Oct 7, 2005 | 06:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
All you need is a standard honing job to seal the rings properly.
Old Oct 7, 2005 | 08:20 PM
EkcivicBeast
thanks guys
Old Oct 7, 2005 | 09:13 PM
qtiger's Avatar
qtiger
Unless your cylinder walls are scratched up or something, in which case you will need to overbore and then hone. However, you still won't need new sleeves unless the old sleeves are totally trashed.
Old Oct 8, 2005 | 06:41 AM
b16ahybrid's Avatar
b16ahybrid
as long as your cylinders are in good shape (no groves, out of round,etc) a simple honing job will do.
Old Oct 8, 2005 | 10:10 AM
EkcivicBeast
thanks, it looks like im gonna just go with da honing,da cylinders look fine
