Help!
Old Sep 27, 2005 | 08:13 AM
psx_pat's Avatar
psx_pat
Default Help!
I did B20VTEC conversion exactly like it says in http://www.c-speedracing.com/howto/b20vtec
But when I drove the car from 1st-3rd gear all shift at 7000 rmps but the VTEC won't kick in. After few times I tried then the check engine light shows up (code 22: oil pressure switch). Also does it matter the size off the hose I use? Cause before I use a slightly bigger hose,the VTEC won't kick in then I use exactly the same as it says on C-speed,still doesn't work.Both of them shows up code 22. Also I checked my oil pressure switch and it's working fine. Anyone knows what is the problem? Thanks.
Old Sep 27, 2005 | 11:33 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Do you have a knock sensor wired up?
Old Sep 27, 2005 | 06:21 PM
psx_pat's Avatar
psx_pat
Yes,I have my knock sensor wired up.
Old Sep 27, 2005 | 08:18 PM
b16ahybrid's Avatar
b16ahybrid
Did you trace tha path all the way to the ecu? or just check voltage at the sensor?
Old Sep 27, 2005 | 10:00 PM
psx_pat's Avatar
psx_pat
I just checked the voltage at the sensor.Yes, I will checked according to the B16 manual. Do you think I get a bad ECU?
Old Sep 27, 2005 | 11:04 PM
psx_pat's Avatar
psx_pat
Is it possible because I milled the head 0.75mm? And I cleaned the head from debris after milling it, so the debris won't get stuck on oil line later.
Old Sep 28, 2005 | 07:30 AM
psx_pat's Avatar
psx_pat
I find out that I don't get enough oil pressure to switch on the VTEC. SO, I will take it apart again the engine and see what's going on? Does this happened to any of you guys? Any suggestion?
Old Sep 29, 2005 | 06:07 AM
psx_pat's Avatar
psx_pat
This maybe a stupid question. Does a VTEC controler can fix my problem?
