Engine Swaping (B18C into 91 Integra LS)
Old Sep 19, 2005 | 06:48 PM
b16ahybrid's Avatar
b16ahybrid
Originally Posted by hachacker5024
yes i know that as little as 3psi can blow it and it could also handle past 18psi but i was asking if anyone here with this engine with a turbo runs how much PSI or knows someone i know very much about the factors of turboing but i was asking what u guys think or know how much PSI this engine can run lets say with all stock internals even though i do not plan on having stock internals
If you understood then you wouldn't be asking this question again.
Like I said before, boost (psi) is NOT a limiting factor for your motor.
Tune for a desired hp not a desired boost level. Poor tuning and exceeding the power limits of your motor will blow it, how many psi you run won't.
Just to appease you, if you run a bone stock engine and your average sized t3t4 (say .50 trim .48 A/R) you can run about 12-14psi depending on your tuning, tuner and set-up. Thats on a b18c or b16a
