APEXi VAFC..worth it?
Old Sep 7, 2002 | 07:33 AM
nodabean's Avatar
nodabean
who farted?
Default APEXi VAFC..worth it?
My friend has a Apexi VAFC on his single cam and swears by it. I was just curious as to anybody elses opinion on these. Is it really worth it for a SOHC? What are the biggest gains one could expect if any? I was considering picking up either the Field or the Apexi if i would see any difference considering im stayin SOHC.
Any help would be greatly appreciated. Thnx.
Old Sep 7, 2002 | 10:41 AM
dubcac's Avatar
dubcac
I
It's good for tuning if you have an aftermarket cam, but you won't get a whole lot of power if that's what you're asking. You can tune fuel a little bit and set the VTEC crossover poing, and have a cool looking display. All this however should be dyno tuned. Most people get a vafc and set the thing to crossover as low as they can, which actually hurts performance. Most people with an aftermarket cam/springs/retainers actually set the vtec xover higher than stock to compensate for the new powerband.
Old Sep 7, 2002 | 09:14 PM
nodabean's Avatar
nodabean
who farted?
so for lightly modded SOHC vtec motors its not really going to have any substantial impact on performance? I am more than likely going to be getting one anyway for future modding or motor swapping. If you dubster99 or anyone else could recommend some tuning specs or settings for a lightly modded D16z6 with a APEXi VAFC it would be greatly appreciated.
Old Sep 7, 2002 | 10:12 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
Like he said, it should be dyno tuned. That said, most people running n/a see gains from cutting fuel 4-5% under VTEC, since the stock map is slightly rich.
Old Sep 8, 2002 | 12:14 PM
integranator's Avatar
integranator
yeah another thing that people think is that they can set the VTEC lower, which will gain more power...but what they don't know is that the AFC merely tells the solenoid to engage earlier--- but doesn't tell the ecu that vtec is engaging earlier. So this results in horrid performance because the vtec lobe requires alot more fuel (obviously) than the non-vtec lobe-- and the ecu doesn't give the increase in fuel until the stock rpm that vtec should engage. Also, afc's are very very helpful in tuning turbo'd cars.
Old Sep 8, 2002 | 01:20 PM
inspyral's Avatar
inspyral
のんびり~(´ε`)
The AFC has VTEC UNMATCH settings that are supposed to account for when the ECM thinks the car is not in VTEC when it actually is, and when the ECM thinks the engine is in VTEC when it's actually not. These settings should, of course, be tuned on a dyno.
Old Sep 8, 2002 | 03:41 PM
nodabean's Avatar
nodabean
who farted?
hmmm i guess ill have to take it to a local dyno shop
Old Sep 8, 2002 | 06:03 PM
dubcac's Avatar
dubcac
I
VTEC makes the valves stay open longer....setting it too low will drastically hurt performance.
Old Sep 8, 2002 | 06:18 PM
nodabean's Avatar
nodabean
who farted?
thanks for the advice guys!! i guess i will have to see where i can get it tuned properly.. ill let my fingers do the walkin =)
Geeq
Jul 21, 2006 11:31 AM
gsr_da
Aug 5, 2005 07:39 PM
VTEC-Power
92+ Civic/EL & Del Sol
Jun 1, 2005 09:09 AM
ZiviCase10287
Engine Swaps, Tech & Tuning
Jul 23, 2003 09:58 PM
Integrity
12
Nov 19, 2002 02:35 PM
