RSX Won't go past 5500 RPM in drive
Old Aug 26, 2005 | 06:43 AM
jamez243's Avatar
jamez243
Default RSX Won't go past 5500 RPM in drive
I've searched and seen one other person had this problem... it's a 02 RSX Type S and when trying to get on it... like at a light or something... It won't go past 5500... every now and then it has... but usually it pegs out like it's hitting the limiter. I understand this would be usual if in park but when trying to race????? Anyone know what could be causing this... thanks.
Old Aug 26, 2005 | 07:03 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Hi. Yes. I'll tell you in a minute but first, Welcome to HAN.
You would have to have it in a lower gear than Drive in order to get it to rev higher, which I do not advise you to do by the way because it will probably do damage.
It's because of the way the tranny is designed to work. And I think the reason you have varying results is because of the terrain that you're driving on. I read somewhere that Acura put a special grade sensing thing in those auto transmissions.
Old Aug 26, 2005 | 07:52 AM
jamez243's Avatar
jamez243
thanks... but the car is a 6-speed .... It pegs at 5500 in first and second gear... It should go up to at least 6500 I believe
kenton's Avatar
kenton
Change sig? Lose [quote]!
In any gear, with 0 speed, the revlimiter kicks in at 5500, this is your maximum 'launch' speed. Deal with it.
Old Aug 26, 2005 | 07:53 AM
kenton's Avatar
kenton
I have an RSX-S so I know what I'm talking about
Old Aug 26, 2005 | 11:08 AM
jamez243's Avatar
jamez243
Dude... will you all PLEASE STOP SAYING THAT... ITS WHEN THE CAR IS MOVING.... not when it's sitting still... I said in each gear... while I'm trying to race.... WHILE CRUSING.... lol I know that when idle it goes at 5500.... thanks
Old Aug 26, 2005 | 12:54 PM
shady visions's Avatar
shady visions
You didn't include that it also does it when you are moving. You just said "when trying to get on it from a light" which implies you were starting from a stop or maybe slight roll.
Also, you said "when in drive" like you were talking about an automatic. And then later you said it was a 6 speed, which it should be if it's a type-s. (i didn't think they made any auto type s's).
I'm just curious, though, what does it exactly do when it "pegs out"?
Old Aug 26, 2005 | 04:21 PM
kenton's Avatar
kenton
i-VTEC fluid low? :dunno:
