B18C1 vs. B18C5
Old Aug 15, 2005 | 05:42 AM
Special K's Avatar
Special K
Default B18C1 vs. B18C5
Hey Folks, I'm not sure if this should be in the hybrid forum or in here, but since they're both Integra engines, I figured I'd start here.
I'm planning on doing an engine swap next year and I'm looking at either the B18C1 or B18C5, with the possibility of a turbo kit in the future. I'm aware of the basic differences between the engines (internals, specs etc.) but I'd like to know just how much power each engine can withstand with it's respective stock internals?
For example, if I were to buy a B18C5, and turbocharge it to the point where I need to upgrade internals, would it not be a better investment (and more reasonable) to buy a B18C1 and upgrade?
As well, how much HP can stock GSR or ITR axles handle?
Thanks for any help!
Old Aug 15, 2005 | 05:53 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
I'm not 100% but it's been my understanding that you'd be better off with a b18c1..
b18c1 = less horses off the bat (170), but can handle a lot more boost in the long run.
b18c5 = more horses off the bat (190), but handles less boost stability..
I don't know anything about the axls, and i'm sure someone'll either say i'm on the right track, or correct my statement shortly, good luck either way.
Old Aug 15, 2005 | 07:19 AM
qtiger's Avatar
qtiger
Axles depend on how you treat them and various other mods. With some nice stiff suspension, slicks, hard poly motor mounts, etc. you can toast your axles with stock horsepower if you launch hard.
Snoopy's Avatar
Snoopy
been there done that
get a b18c1 and save yourself some cash. then put that into building it for boost.
Old Aug 15, 2005 | 08:43 AM
Joe's Avatar
Joe
Im also swapping next year to a b18c1
Old Aug 15, 2005 | 09:01 AM
MathGSR's Avatar
MathGSR
Keeping your stock internal won't let you boost very much. Or you'll need gas with very high octane...
Compression:
B18c1 USDM = 10:1
B18c1 JDM = 10.6:1
B18c5 USDM = 10.6:1
B18c5 JDM = 11:1
Boosting your engine with a turbo create more compression and more compression result detonation if you don't have the right gas octane. For example, if you put a turbo into the b18c1 USDM you'll be able to boost 7-8 PSI on 94 octane (maybe 91 with fire retard...). If you want more boost you have to change your piston for lower compression pistons...
So putting a turbo into a type-r with stock pistons and normal gas is bad.
A b18c1 at 7-8 psi would be great. I have a 98 GSR and the performances are very impressive since it's a 1.8 liter. Adding a turbo at only 7-8 psi would make it a pocket rocket.
Old Aug 15, 2005 | 09:15 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:nono: The hybrid forum is that way, folks....--->>>>
[I swear, I feel like a traffic cop sometimes. :run:]
Old Aug 15, 2005 | 11:10 AM
sherwood's Avatar
sherwood
I missed Sean
uh... this really has nothing to do with hybrids and everything to do with engine tech
anyway, get the c1
Old Aug 15, 2005 | 02:06 PM
Special K's Avatar
Special K
Thanks for the insight folks, much appreciated!
