93 civic ex keeps blowing back up fuse
Old Aug 3, 2005 | 04:08 AM
bigmoneypimp's Avatar
bigmoneypimp
Default 93 civic ex keeps blowing back up fuse
my sisters EX just stopped running. thinking maybe fuel pump b,c i removed the line and turned the car over and no fuel ever came out and plus you cant hear the pump turn on. but i was checking the fuses under the hood and the backup fuse 7.5 amp keeps blowing as soon as i put it in.
Old Aug 3, 2005 | 06:06 AM
shivers's Avatar
shivers
Moderator Alumni
Sounds like you need to track down a short in the wiring somewhere.
2005 s2000
Old Aug 3, 2005 | 06:13 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Agreed. There's likely an exposed wire somewhere that is related to that fuse that is grounding out.
Old Aug 3, 2005 | 10:21 AM
bigmoneypimp
i checked the fuses under the dash and the ACG (S) fuse 15 amp was blown. so i changed it and the car started but the fuse blew again and the car cut off, SO where should i check ??? im new to HONDA'S , im a dsm guy. haha
