B16 OBD0 Head conversion to OBD2
Old Jul 17, 2005 | 02:18 PM
steven_SA's Avatar
steven_SA
Default B16 OBD0 Head conversion to OBD2
I bought a OBD0 B16 1st Gen head off ebay for my ls/vtec conversion not knowing it was a OBD0. I am running a OBD2 ECU and wiring harness. Is there a way to convert the head to a OBD2 head by maybe putting on a GSR distributor. Or is there anyway around this problem. Thanks in advance.
Old Jul 17, 2005 | 02:59 PM
teg92's Avatar
teg92
WHAT OK YEAH!
You will have to change the Dizzy, Fuel injectors, and maybe the Intake Maifold
Old Jul 17, 2005 | 03:15 PM
steven_SA's Avatar
steven_SA
the ls is all obd2 just the head is obd0 is there no other way around this problem. The head i have has no intake manifold with it. Just the B16a head with the dist and vtec soleniod.
Old Jul 17, 2005 | 03:19 PM
teg92's Avatar
teg92
WHAT OK YEAH!
so what Intake Manifold were you planning on using?
Old Jul 17, 2005 | 04:44 PM
steven_SA's Avatar
steven_SA
I have a Type R on the LS at the moment. Am i able to use it.
Old Jul 17, 2005 | 08:38 PM
qtiger's Avatar
qtiger
Your life will be much simpler if you use an OBD1 ECU.
Old Jul 18, 2005 | 07:19 AM
steven_SA's Avatar
steven_SA
thats what i plan to do. Going to get a OBD2 to OBD1 conversion harness and run a P28. I will just use the LS dist on the B16 and that should sort my problem out wont it ?
