B16A problem.
Old Aug 5, 2005 | 03:45 PM
ginomobile/teg's Avatar
ginomobile/teg
It could be the main fuel relay acting up when the weather is hot...i had that problem with my ls..
Old Aug 6, 2005 | 11:48 AM
psx_pat's Avatar
psx_pat
But when it happened I checked the fuel pressure is good. So, is it possible still the main fuel relay?
Old Aug 8, 2005 | 09:01 PM
FA9S8U's Avatar
FA9S8U
I'd doubt it...your getting fuel under pressure to the fuel rail.
Old Aug 9, 2005 | 02:43 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
After I drive my car for a while say 20 minutes then my engine start to hesitate and then shut down especially when the temperature outside is hot and when the engine load is heavy (uphill). But after leave the engine off for 2-3 minutes and then the car can go for another 1km or so before it's start to hesitate again (even on flat road). Could it be the sensor (I don't know what it call) near the oil filter, looks like O2 sensor, with 2 cable (color yellow/green and black)? Anyone know? Please. Thanks.
check your igition.
Old Aug 24, 2005 | 12:09 AM
psx_pat's Avatar
psx_pat
I did change the ignitor but the problem won't disappear. Also I switch the PS91 crane cams coil to LX91 crane cams coil, still not solve the problem.I haven't change the whole distributor cause is hard to find here.Anyone, knows what else could cause the problem? Thanks.
Old Aug 30, 2005 | 11:55 AM
RevengeCRX's Avatar
RevengeCRX
89 CRX si, now with b16!
Could be main relay, cutting in and out sometimes sending fuel, sometimes not, but not sure. Is ECU throwing codes? CEL does not always come on even if ECU is throwing codes. If not main relay, then check rotor, cap, wires, and plugs. If that still doesn't help, then i would check injectors, they may be good when cold, but when warmed up, injectors may fail, and cause you're car to run poorly, and look for possible causes for injector problems, like fuel filter or poor connections. Just my .02. Good luck.
Old Aug 31, 2005 | 07:49 AM
psx_pat's Avatar
psx_pat
Ok,I'll do that. Thanks.
Old Sep 7, 2005 | 05:35 AM
psx_pat's Avatar
psx_pat
Man,still haven't figure out what the problem is. But one thing I notice recently when I'm going downhill or uphill the problem seems to get worse. Is it possible because of the position of the car can influence how the car parts working? If it does,does anyone know what possibly the problem? thanks.
Old Sep 11, 2005 | 09:44 AM
redscorcher's Avatar
redscorcher
I just worked on a pontiac with this problem. The injectors were very dirty. you'll get cut out underload after warmup. Try some sea foam you should notice improvement. But if your car continues to cutout try some different injectors. Either that or just get yours cleaned. Also question? does it heat up any when this cutting out occurs?
Old Dec 16, 2005 | 11:43 AM
mareho's Avatar
mareho
b16ahybrid why did you ask if he had a field sfc vtec controller
