Bad engine noises
Old Jun 24, 2005 | 10:06 AM
Rotor_head's Avatar
Rotor_head
Default Bad engine noises
Juat got back from a month away for business, and my girlfriend says my honda was making "funny sounds". One morning she started it and the engine was making a clunking sound from the lower left hand area, and the engine was shuttering. I took it for a spin when i got home and it sounds as strong as ever. I think it was just some water in the fuel, but a "know-it-all" buddy of mine says i spun a crank bearing. What would be some indications of a spun bearing?
'98 Si D16Y8 all stock.
Old Jun 24, 2005 | 10:07 AM
Rotor_head's Avatar
Rotor_head
Engine only has 96k Kms on it, and has been drivin' easy.
Old Jun 24, 2005 | 10:45 AM
mberndt's Avatar
mberndt
I think if it was a spun-bearing, it would prob continue to make noise/vibration until it broke, at which point you would def. be able to tell. I have those friend's too, but sometimes they are wrong also, lol.
Later,
Mike
Old Jun 24, 2005 | 11:44 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
A spun bearing would make a consistent rod knock until it eventually distroyed the bearing.
If it is an on and off noise, it probably isn't a spun bearing.
Old Jun 24, 2005 | 01:09 PM
Rotor_head's Avatar
Rotor_head
Ya thats what i thought, it only happened once. It was probably just condensation in the tank, and she got a gulp of water. H2O doesnt burn worth a s**t. Thanks guys.
Old Jun 25, 2005 | 10:20 AM
ksolo101's Avatar
ksolo101
Im having the same noise coming from the lower left front area, im thinking maybe it could be a spun bearing? idk im taking it in to the shop later to see what they say check ur crank pulley if it vibrates then maybe there is a problem with ur bearings, if not then ur probably right about the condensation
