K&N Intake Wierd Noise after engine turn off
Old Jun 6, 2005 | 05:34 PM
AccordEXV6's Avatar
AccordEXV6
Default K&N Intake Wierd Noise after engine turn off
A recently put on a K&N cold air intake on my 03 V6 ACCORD COUPE WHEN I turn the car off, it makes a weird hsss... type sound. Does any one else have this??
Old Jun 6, 2005 | 05:36 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I do. :awais:
Mine does it because the pressure equalizes between vacuum in the manifold and standard pressure outside after I shut the engine off. It is just allowing air to come into the manifold to take the place of the vacuum. Yours may be due to the same thing, but it doesn't sound like something to be worried about.
Old Jun 10, 2005 | 12:59 PM
ksolo101's Avatar
ksolo101
i hear a hsss noise too but only for like 3-4 seconds
its completly normal unless its something other than what im talking about
Old Jun 22, 2005 | 03:29 PM
B16a2VTIguy's Avatar
B16a2VTIguy
Built B16a
I have a 94' civic vti (b16a2) it has a induction kit on it and i hear it every time i turn my car off, its just because the engine breathes so much, when u shut ur motor off its still turns a few times before it actually stops...so while its turning its still sucking air in even though its had the fuel and ignition stopped from it.
Old Jun 22, 2005 | 07:47 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
mine does the same thing
Old Jun 22, 2005 | 08:56 PM
Provocateur
On permanent hiatus
Then, it must be normal.
Old Jun 26, 2005 | 09:33 AM
2legit2quit's Avatar
2legit2quit
You Big Dummy
It is normal.
That is why.
Old Jun 28, 2005 | 09:01 AM
b18cswap's Avatar
b18cswap
my b18 does that as well, it sounds like its still sucking air.
