valvetrain
Old Jun 5, 2005 | 04:10 PM
GSR-Papi's Avatar
GSR-Papi
Titanium retainers ARE better for heat dissipation, they are also lighter. Light valvetrain is better, and boosted engines run much hotter than NA setups, that's modding 101 right there. The "increased friction" high lift cams create on the valvetrain is minute compared to the super high cylinder pressure created in a boosted engine cylinder, and therefore heat.
99% of NA setups don't need aftermarket retainers, the only thing they'll do for you is up your bling factor.
I may only have 12 posts on this site, but I'm no newb.
Old Jun 5, 2005 | 04:38 PM
jam05pr's Avatar
jam05pr
so i should be fine with lets say some skunk2 valve springs
Old Jun 5, 2005 | 04:52 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
So a 13:1 compression ratio N/A motor doesn't create super high cylinder pressures? A 9500rpm N/A motor puts more friction on the valvetrain than a boosted motor 8000rpm FI motor does, especially when high lift N/A cams are being run.
I don't know where you are getting this idea about a forced induction valvetrain running hotter than a high compression N/A valvetrain. It may be the case when running a ton of boost with high lift turbo cams, but with basic turbo setups like mine, it is definitely not true.
I'm not saying that you are a noob, but what you are saying doesn't make sense to me especially considering I have a boosted motor.
I agree that aftermarket retainers aren't necessary, but any measure to reduce friction (heat) is a good idea, especially when everything is taken apart.
Old Jun 5, 2005 | 05:30 PM
ED9man's Avatar
ED9man
driver
Higher rate springs will suck power if you don't need them. You want the softest spring possible while not getting any valve float at top rpm.
What is a retainer's function?
Old Jun 5, 2005 | 06:57 PM
jam05pr's Avatar
jam05pr
so i will loose power if i put them on?
Old Jun 6, 2005 | 11:51 AM
jam05pr's Avatar
jam05pr
Old Jun 6, 2005 | 12:40 PM
ED9man's Avatar
ED9man
driver
If you are running a stock cam, you don't need them unless you are upping the redline.
Old Jun 6, 2005 | 02:20 PM
jam05pr's Avatar
jam05pr
I'm not necessarily wanting them to up the redline right now. I just want to know if I will be ok using them with a stock cam. In other words, are there any dowsides?
