LS/Vtec Timing Belt
Old Jun 4, 2005 | 08:22 AM
b18c1_hatch's Avatar
b18c1_hatch
Default LS/Vtec Timing Belt
OK kinda confused with is i need a new timing belt and Gaskets but for the applications for the timing belt i dont no what to choose i have B18a bottom block with a 95 gsr head now what kinda timing belt application should i get. b18 oem timing belt or b18c oem timing belt.
ALso i need new top end head gaskets should i get the b18a oem gaskets or b18c1 oem top end gaskets but the thing is are the Cylinder bores the same for a LS/GSR which is 81mm. sorry for the dumb questions i would like some answers thanks.
Old Jun 4, 2005 | 07:29 PM
Snoopy's Avatar
Snoopy
been there done that
if you're using a nonvtec water pump, use a nonvtec belt. vtec pump, vtec belt.
Old Jul 19, 2005 | 08:22 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i've read a lot about this. so far my setup is a b18a block with a b16 head. all the forums say use itr or gsr timing belt, water pump, and oil pump. will a b16 oil pump, water pump and timing belt work with my block and my setup?
Old Jul 20, 2005 | 04:03 PM
Snoopy's Avatar
Snoopy
i dont know about the pumps, but the timing belt will not fit. it is shorter than a b18 belt.
