Help 99 civic !!!!!! my car cut off
Old May 19, 2005 | 03:41 PM
lilgdog7's Avatar
lilgdog7
Default Help 99 civic !!!!!! my car cut off
Help!!!!!
Ok, so i'm at a turn light waiting to turn and suddenly the car just cuts off!!! I restart and while im drivinng 30 yards from where it just cut off , it cuts off again. So, i pull over and wait a while. I restart it and make it home. I went to autozone to have the test the battery and they said the battery and the alternator are both good. So what could be wrong?? any help???
4dr 99 civic
Old May 19, 2005 | 06:31 PM
critter sit-t's Avatar
critter sit-t
Critter SIR-T
fuel filter
Old May 20, 2005 | 05:43 AM
Poorboyz's Avatar
Poorboyz
fuel pump?
Old May 20, 2005 | 05:58 AM
civicandtegra's Avatar
civicandtegra
the fuse for the fuel filter
Old May 20, 2005 | 08:10 AM
JimBlake's Avatar
JimBlake
I never knew the fuel filter had a fuse.
Blown fuel pump fuse would remain blown. It doesn't fix itself by waiting awhile.
Ignition module (ignitor) might be going bad. Cuts out when hot, then works after it cools off.
If you can make it happen again by wiggling the key, that would be your ignition switch getting flaky. That's sorta common for Hondas.
Old May 20, 2005 | 08:50 AM
civicandtegra
no i meant the wire to the fuse and pump has a split in it so it doesnt always meet and send power
Old Jun 1, 2005 | 02:17 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Check your vacuum hoses, fuel pressure, and idle speed (an increase may help). A bad igniter (Ignition Control Module) usually deals with misfire, and no-start. hmm ignition switch makes a running car cut off? hmm I never knew I had to hold the key to keep the car running lolz.
Old Jun 3, 2005 | 06:23 PM
flatliner's Avatar
flatliner
Fix It
fuel pump or ignition coil.
