Crankshaft Pulley Bolt threads 92 Civic
Old May 14, 2005 | 04:14 PM
ronray43's Avatar
ronray43
Default Crankshaft Pulley Bolt threads 92 Civic
Hi, I need to take the crankshaft pulley off my 92 Honda Civic, 1.5L, 16V (engine D15B7). The photo in my Haynes manual shows the tech bracing the flywheel to prevent the engine from turning as if he's going to turn the crankshaft pulley bolt clockwise, even though that particular picture is being referenced during the crankshaft pulley bolt removal procedures. If this is right, then the crankshaft pulley bolt would be left handed (clockwise to loosen; counterclockwise to tighten).
Which is it????!!!! Last thing I need to do is to turn it the wrong way and break the bolt off!!
Cheers,
Ron
Old May 14, 2005 | 05:25 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It's left-loose, right-tight.
Provocateur's Avatar
Provocateur
On permanent hiatus
It is threaded normally. You would turn it clockwise to tighten, counterclockwise to loosen.
