Eliminated my breather tube heater
Old Jun 6, 2005 | 09:59 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
Originally Posted by servion
The oil vapors decrease the effective octane of the fuel, thereby increasing chances of detonation.
Do a little research (from credible sources) before you continue to babble on.
Nobody's babbling here, what you are saying is wrong. Seriously do you know what detonation is guy? I don't think posting a quote from somebody else makes your theory correct either. Try again, maybe enlighten me by explaining detonation then go into why octane is somehow changed or made less effective by oil vapors....Please use details and explain yourself instead of using someone else's quotes.
Old Jun 7, 2005 | 09:07 AM
servion's Avatar
servion
I recommend you do some research (i.e., search) regarding this topic before you try to tell people how their setups work or give advice on making them better. The spread of misinformation (like what you're doing nere and now) is a huge reason why honda owners get such a bad rap: they blow their motors by listening to all the things "they've heard" on the internet or elsewhere. In regards to my first quote, if you haven't yet heard of Endyn, you probably haven't been in the honda modification field for long.
I have no idea what detonation is, it's not like I tune other people's cars professionally or anything like that.
Oh wait, yes I do. Here's the last car I tuned (I'll give you a hint: its owned by a respected, long-time member of this board):
91 octane pump gas.
Do you understand what an octane rating is? Its a fuel's ability to resist ignition. Here's where you can really learn about detonation
I'll give you a hint: oil vapors have a lot lower octane rating than fuel. What happens if you mix a lower octane combustible with a higher octane combustible? Say, for example, you decide to mix in 1/2 a tank of 87 octane fuel into your gas tank whish is 1/2 full of c16? The final octane rating of the mixture is significantly lowered.
Boosted Hybrid (Jeff Evans of Evans Tuning) is one of the nation's best EFI tuners.... here's his description of the typical catchcan system (taken from here):
Originally Posted by Boosted Hybrid
The purpose of a catchcan is to "catch" the oil vapors that are typically passed into the intake manifold with the exhaust gas recirculation system on engines. Oil degrates the octane quality of the fuel that you are using. If you can seperate the oil vapors, you can actually run the full amount of octane of the gasoline that you are using and inturn squeeze 1-2 more psi safely from a pump gas setting.
Another aspect of a catch can system is that it relieves crankcase pressure. The freeze plugs in the back of the block are removed, and you vent the crankcase vapor directly from the back of the block instead of forcing it through the stock oil vapor seperator. The key is that you are taking the vapor from two seperate locations on the block, this allows for double the "breathing" of the crankcase thereby relieving more pressure.
Its a two fold system. The filter on the valve cover breather just doesnt let the oil vapor from the head breathing system to pass back into the intake stream. Again, this saturates the incoming air with oil vapor dropping air density and octane level of fuel being used. Its best to have a can "catching" the two locations on the block, and the valve cover breather.
Old Jun 7, 2005 | 02:34 PM
qtiger's Avatar
qtiger
I don't have any problem with members arguing and contending ideas in this forum. It's much more educational because it forces people to think rather than just taking what's said as gospel and becoming a little Honda zergling.
However, the difference between debating what someone has said and being a jackass is how you word what you say. That being said, lets try and keep it friendly and intelligent in here.
Old Jun 14, 2005 | 02:24 PM
PahLok's Avatar
PahLok
Lisbon Mafia Connection
The air goes from the valve cover into the intake. removing it doesn't give you anything. It's pretty lame that ppl still are doing it and think they are getting anything from it.
errrr... I didn´t remove it, I removed the coolant passage near that tube. Read carefully please.
Servion thanks again for some great explanations, and you´re right it's very easy to get the wrong info on the net.. and so hard to get the right info
So from my understanding best setup for max. engine (on NA and turbo) is a filter for the head cover and a catch can for the locations on the engine block.
bubye
Old Aug 6, 2005 | 03:53 AM
hondatech's Avatar
hondatech
bubye
The wrong info is from Servion.
Old Aug 6, 2005 | 02:26 PM
servion's Avatar
servion
I really think you are the coolest guy. I just wanted to let you know that, and that I love everyone in this forum... each and every one of you. Edited by qtiger
Why, thank you for the kind compliments hondatech
I suggest that you either post some real-world evidence or at least a solid argument to attempt to prove your point.
Old Aug 7, 2005 | 10:36 AM
hondatech's Avatar
hondatech
I guess working on cars at a dealership level for years isn't "real world exprience"
Old Aug 7, 2005 | 04:28 PM
qtiger's Avatar
qtiger
I believe he said evidence not experience.
And, for future reference, quoting others is good. Showing another person's argument is also good. It shows that other people think the same way you do.
Old Aug 7, 2005 | 05:41 PM
hondatech's Avatar
hondatech
I can read thanks, in all my experience(which is vast) I have never seen it happen. And I do not agree with you on quoting others, just because another person agrees or disagrees doesn't mean you are correct or incorrect.Also unrelated dyne sheets and "name dropping" doesn't make you correct either.
I still have not and suspect WILL not ever see prove of his theory that oil vapors will cause detonation.
this is his example:
Oil vapors are not fuel so they have no octane rating, 87 octane fuel burns faster not slower if you were to add oil vapors to the mixture (oil has an extremely low flash point) and if it were to affect the octane it would burn slower and no detonation would occur.
Old Aug 7, 2005 | 05:58 PM
qtiger's Avatar
qtiger
Octane reflects a fuel's resistance to ignition. 93 octane is harder to ignite than 87, that's why it is used in high compression engines.
You also directly contradicted yourself in your post. Oil has a low flash point, and thus would tend to ignite in the cylinder before the spark plug fires. Behold, detonation.
