Which Injectors on LsVtec? B16a or LS?
Old May 10, 2005 | 02:28 PM
JayDeeEmDC4's Avatar
JayDeeEmDC4
Default Which Injectors on LsVtec? B16a or LS?
Should I use my stock LS injectors or the obd1 B16 ones that came with the motor? Im using a obd1 P30 ecu btw. Is the anything else I should take off the b16 motor so that it will be compatible with my ecu?
Old May 10, 2005 | 03:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I believe they are the same in terms of flow rate, 240cc. Use whatever fits into the harnesses.
Old May 11, 2005 | 05:25 PM
JayDeeEmDC4
I mean as far as the wiring end of it goes
Old May 11, 2005 | 08:40 PM
Provocateur
On permanent hiatus
If you have new harnesses that you need to splice in for a OBD2 to OBD1 conversion, the wires hook up completely identical to OBD2. Negative goes to negative and positive goes to positive. Make sure you solder or splice clip them in and then shrink tube them.
Old May 12, 2005 | 02:04 PM
JayDeeEmDC4
should I just use the obd1 b16 injectors that came with the motor since im using the obd1 p28 that I have?
Old May 13, 2005 | 10:21 AM
Provocateur
On permanent hiatus
yes.
Old May 13, 2005 | 12:58 PM
JayDeeEmDC4
then there wont be any problem right?
Old May 13, 2005 | 08:25 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
Hey Mark who cares...you stole that engine!
Old May 13, 2005 | 08:26 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
pretty scummy move...and im disapointed in you.
