Knock sensor wiring
Old May 9, 2005 | 01:24 AM
krusty990's Avatar
krusty990
Default Knock sensor wiring
In the process of making wiring changes to my EK/B18C swap I noticed that the knock sensor is connected back to the ECU with a Shielded wire. This type of wire is not readily available. Has anyone doing this conversion experienced any problems (ie. trouble codes) if a NON Shielded cable is used?
