B18 sir-g From H-motors
Old Apr 30, 2005 | 02:34 PM
gsr wannabe's Avatar
gsr wannabe
Default B18 sir-g From H-motors
Ok, I know that the b18c 94-97 'gsr' complete changeover from H-motors is a b18c sir-g. What, if any, are the key differences in these engines other than thier country of manufacture and the different compression ratios from usdm to jdm. I plan on turbo, hondata, lots of other goodies, but I want to make sure all my planning and parts lists will work for this engine. Lots of GSR aftermarket parts already here--should I get this engine, or should I look for a usdm gsr?
Old May 1, 2005 | 05:28 AM
ED9man's Avatar
ED9man
driver
SiR-g is automatic no?
Old May 1, 2005 | 09:47 AM
Snoopy's Avatar
Snoopy
been there done that
sir-g = jdm gsr
if you'll be tearing the engine apart and replacing stuff there's no reason to spend more for the jdm engine.
Old May 2, 2005 | 08:37 AM
gsr wannabe
Thanks for the help...Just curious, how do you tell the difference between the two by looking at a picture...I can't tell...I guess it's something small and specific...What is it? (you can name the part, I'll know what you're talking about--One other thing...the cheapest usdm gsr swap kit, (sohfast.com) is about 900 more than the hmotors jdm gsr even with LSD. not to mention you pay more for a usdm swap the lower the miles are. Lowest mileage on a usdm gsr swap I've found was 80k +.If anyone knows where to find a usdm gsr swap that's cheaper/more reliable than what I would get from hmotors, please, let me know.
Old May 2, 2005 | 08:45 AM
Snoopy's Avatar
Snoopy
cant tell just by looking at a pic unless the pic is a close up of the engine stamp and model stamp on the head.
Old May 2, 2005 | 09:36 AM
gsr wannabe
thanks. How about a usdm gsr complete change over for cheaper than the jdm gsr from h motors that doesn't have 80k miles plus? sohfast.com is the only usdm specialist that I've found.
Old May 16, 2005 | 10:30 PM
99teggsr's Avatar
99teggsr
so see the differance look at the stamp on the tranny housing, b18c = JDM GSR, b18c1 = USDM GSR. If the jdm gsr is cheaper and has less miles and has a lsd then why the hells not ? The JDM one makes about 10 more power anyway. If you are tearing it down usdm VS JDM is really not an issue. even if you werent rebuilding it I wouldnt wory, I dont think ive ever seen GSr aftermarket parts usdm or JDM specific, they're really the same engine except for slightly higher comp pistons, and maybe a few other very very small insignificant things. I just got a JDM gsr from hmotors with 37K miles with LSD for 3300 shipped. Bottom line is to go JDM, its cheaper and a better engine.
