Need help please!!!! pin out for the b16 ecu
Old Apr 28, 2005 | 07:38 PM
madman4you's Avatar
madman4you
Default Need help please!!!! pin out for the b16 ecu
im having a problem with the wiring. i didnt want to buy a new wiring harness after the one on my new b16a first gen was cut i got the ecu without the clips that go into it.But i later bought the clip parts that fit into the ecu, but they only have a little bit of wire length. I was planing on just matching and extending the wires because i do have another b16a engine harness but its cut aswell and its a automatic. So what i have, is the harness that comes from the engine, the middle parts where the harness clicks into the harness from the fire wall, then the clip parts that are in the actual ecu. however some of the wires are a little different. i need a nice pinout of the harness from the engine to the ecu and what colors do what can any one help.
Old May 3, 2005 | 01:04 PM
PHiZ's Avatar
PHiZ
BOOST GOD
We have no idea what generation any of this stuff is. Need more info.
-PHiZ
Old May 3, 2005 | 10:51 PM
psx_pat's Avatar
psx_pat
Try go to this site, it might help
http://www.hondata.com/techwiringpw0.html
Old May 4, 2005 | 04:16 AM
madman4you's Avatar
madman4you
thanks. sorry it was a first gen b16 88-91 obd 0 but i found out already thanks again.
Old May 4, 2005 | 07:48 AM
psx_pat's Avatar
psx_pat
No,problem. Also could you find out, OBD-0 have 2 O2 sensors. one on exhaust #1&#4 and the other one is exhaust #3&#4. Which one is going to ECU pin number C16 (white cable). Thanks.
