1994 integ ls
Old Apr 13, 2005 | 06:20 PM
sMiLeY's Avatar
sMiLeY
Ls TeG
Default 1994 integ ls
turn key....click click click...hmm...change starter..still click..click..click....hmmm....check voltage of wires to starter...hmmm all good... check battery level...hmmm still good...so if amp n volt aint a problem any ideas? everything else seems fine, i dont fricken understand it so far im gonna get another starter in case its that. any one else have any ideas. the car does start fine on a bump start, it can turn over manually, it should fricken start!
Old Apr 13, 2005 | 09:21 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Is it a rapid clicking or a slower clicking?
I had a rapid clicking and I just cleaned my battery terminals and tightened up the cables and it hasn't done it again.
My dad's car is currently having a slow clicking and in that case, it is the starter. I am going to replace his this weekend and hopefully that will fix it.
Old Apr 14, 2005 | 05:10 AM
JimBlake's Avatar
JimBlake
I see where you measured voltage, but I don't see where you measured amperage...
Lots of bad batteries & bad cable connections measure good voltage when there's no electrical load.
