Next modification?
Old Apr 6, 2005 | 05:35 AM
psx_pat's Avatar
psx_pat
Default Next modification?
I want to do some performance modification to my B16A engine. So far, I have intake, header, exhaust, SCI ignition and Crane Cams coil. What do you guys think would be best for the money for my next upgrade I should do? But I don’t want force induction so no turbo, supercharger or NOS at this time. Thanks.
Old Apr 6, 2005 | 05:44 AM
Illegal B16's Avatar
Illegal B16
New Zealand
Cams, throttle body, intake manifold, engine mounts, hondata
Old Apr 6, 2005 | 08:55 AM
Eclypz's Avatar
Eclypz
probably too early for a hondata, but cams would be a good start.
Old Apr 6, 2005 | 11:57 AM
psx_pat's Avatar
psx_pat
Which one is better, change my cam (stage 1 or 2?) or change my TB and intake manifold? I want something good for everyday driving and if I could I want keep good idle and low end power, cause I heard if you change the cam you might loose some low end power. Thanks.
Old Apr 6, 2005 | 12:04 PM
Snoopy's Avatar
Snoopy
been there done that
nothing short of a supercharger is going to give you low end. a set of cams is going to give better gains than a tb/im.
Old Apr 6, 2005 | 12:43 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Are you sure it is a B16A? You said one cam. :eh:
Old Apr 6, 2005 | 01:44 PM
hakjai's Avatar
hakjai
is money an issue? a good NA build is going to be costly
Old Apr 6, 2005 | 04:59 PM
raiden571's Avatar
raiden571
turning u inside out
itb's would be cool. you could make your own for fairly cheap too, you need them from i beilieve a suzuki gsxr 600 and then get an intake manifold and cut the runners. there are diys all over the net, hit up google, ull find it
Old Apr 6, 2005 | 05:30 PM
Illegal B16
New Zealand
Your engine doesnt have enough compression or displacement to run stage 2 cams.
Old Apr 6, 2005 | 11:36 PM
psx_pat's Avatar
psx_pat
It's B16A, I meant cams. Yeah, I heard to change to stage 2 cams I need to increase CR. Well, I want to go for N/A but I just want to get the right direction/sequence of which I should upgrade first. I'm thinking about T/B and I/M change to 64mm. But there are also many people suggest cams will gain more power than T/B and I/M. Again, if I go for cams, I will gain more power in the all rpm's or only in high rpm's? Because I heard if I change T/B and I/M I will gain power in all rpm's range. Thanks.
