ZC Swap - Timing/Distributor
Old Mar 23, 2005 | 10:51 AM
parkerfly's Avatar
parkerfly
Default ZC Swap - Timing/Distributor
I'm swapping a ZC into 1 91 CRX HF. Got everything bolted in and hooked up but seem to have a distributor and possible timing problem.
1) I removed the distributor and found its very hard to rotate, pretty much need a screwdriver to turn it... I'm guessing this is not only not good but means I need a new distributor. Ouch!
2) When the #1 piston is at TDC and the cam sprockets are pointing up... the distributor is pointing at #3? I put my orig distrib up and it points to #1 like it should (Too bad I can't use that one). Is it possible the something got shifted or twisted inside the ZC distrib to make it point to the wrong cyl?
Thanks
Don
